How to fix Lenovo android phone boot problem
gronaldojr23
10
I had a lenovo A680 suddenly stopped from functioning. I tried to turn in back on and it stays on its logo and does not continue. I've waited already for an hour and nothing happens. I tried formatting it using the recovery and also I tried wiping out the cache and still it does not continue. Maybe is there any solutions for this problem? By the way the power and volume button is damaged so it is kinda difficult to turn it on using only the power button. And lastly it is not rooted
This usually means a problem with the firmware (i.e, corruption) or the hardware (perhaps the motherboard). You could try searching for a way to re-flash the stock ROM, if possible--check the forums at xda-developers.com. Good luck!
I cannot even pass through the logo and it says that I need to change something in developer options. So I can't possibly do what it says
Hmm, sorry--not sure what else you can try. It might be time to bring it to a repair shop and get an estimate.
customer28
