How to automatically power off the phone after a certain amount of idle time?
tinker1234
81
Android 4.4 KitKat
LG Volt
Virgin Mobile
I keep finding myself with a low battery either by forgetting to turn my phone off or having the on switch unknowingly pushed when I stuff my phone into the pocket of a messenger bag.
Is there a way I can tell Android ( 4.4 KitKat ) to power down after a certain amount of time if I am not pressing buttons and an app like GPS isn't running?
I find some instructions similar to the ones at this link, but my version of Android does not have a "Scheduled power on and off" menu option ( at least not in the same place ).
http://www.trishtech.com/2014/06/schedule-android-power-on-off-automatically/
I also don't want to power down at a scheduled time. I want it to power down as a result of inactivity.
Thanks for any help.
Hi! I am not sure if "setting a turnoff time" like this is possible. But you can always set an alarm on your phone to charge it by X o'clock every day, if that helps. :)
hawkeyedigital
