Android password requested after fastboot
JKarhani
21
Hello,
I am trying to reset an intel machine with android 5.0 using fastboot.
If I do a complete reset, I have no problem, it encrypts normally & boot & works as a charm.
But what I need is to reset the machine while keeping the data, so I removed this command:
fastboot format data
After booting the machine I got a screen saying "to start android, enter your password"
whatever last password enetered, I get the folowing (as if the password is wrong) & start resetting the machine..it works well, but no data is there too.
I have no idea to what password does it means nor any of my known passwords work.
Any Solution?
N.B : I tried with the screenlock password when i had one & it didn't work.
Hello there.
If you enabled the option to ask for a password/PIN on boot, when you start up your device, before the full-boot process is completed, the system will ask you for your password/PIN.
This is the same PIN you would use to unlock your device after it has been asleep. Basically the screen-lock password.
hELLO D13H4RD2L1V3,
thank you but I tried it before & didn't work.
Not sure what's up, but it's likely that something got messed up during the fastboot process which may have rendered your screen lock password useless.
No here you go, the password is 12345678
whatever you put as yr pinlock!!
thank you, closed.
MWavy06
