Disable android on-body detection suggestion
zikohh
10
Before the latest Android security update every time I have some form of Do Not Disturb on I get suggestions from Android to enable On-Body Detection. I click on the three dots and then it goes away - temporarily that is and it just keeps coming back.
Try going to Settings -> Security -> Smart Lock -> On-body detection. Turn it on and then off again.
Once you have done this, it may stop those annoying suggestions.
What phone are you using?
liquidsnake757
