I'm a new convert to Android from Windows Phone. On that device, when you were on Bluetooth (like a speaker or a headset) if you had an incoming text it would pause the music or podcast, then tell you you had a text, ask if you want to read it, then do so if you told it to. It would even ask you if you wanted to reply.
On a speaker this morning, I got a text message but only heard the incoming text alert. Is there a setting that I can't find to fix this? Or is this just not an option on Android? (I haven't yet received a text while driving, so I don't know if it works there)
