Kyledake New member Mar 15, 2018 2 0 0 Mar 15, 2018 #1 All I can do is change the sleep settings. No option to keep the phone's screen from going black after 10 seconds or so
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,100 10,272 113 Mar 15, 2018 #2 Welcome to Android Central! Are you trying to change the screen timeout for the lockscreen? That typically can't be adjusted -- the screen timeout is for when you're on the homescreen.
A antkowiak New member Mar 22, 2018 3 0 0 Mar 22, 2018 #3 Pretty sure this is NOT a result of user-error. See my more comprehensive reply in: https://forums.androidcentral.com/a...locks-after-fifteen-seconds-how-do-i-fix.html
