Hello,
I have a Samsung Galaxy S7 Edge running Oreo that was factory reset due to an error in an update. I have spent hours looking at different data recovery s/w options. It looks like many of them require rooting, something I have never done before. I don't care about voiding a warranty, but do not want to brick the phone either.
My main goal is to recover my SMS texts (ones that are in the messaging app and ones that I have saved/archived over the years) as well as my apps. Most of my photos were on an external card and are fine. I also have my contacts saved to Verizon Cloud.
I have downloaded free trial versions of several data recovery apps and all of them say I will get the best results if I root the phone. When I scan my unrooted phone, they only discover a few messages and contacts.
Is there any app that can recover a decent percent of my lost files without rooting the phone?
If I need to root the phone, I like the idea of simple one button rooting. Yet, how do I know that I am not installing some nasty malware? I found a site that recommended KingoRoot, iRoot, and KingRoot. Anyone have actual experience with these apps?
What about apps like PhoneRescue for Android that have there own built-in rooting s/w. Are these any good?
I'm overloaded with info and looking for advice on a tried and tru solution, hopefully for under $50.
Thanks!
P.S. Apps I looked at:
MiniTool Mobile Recovery for Android
MiniTool Power Data Recovery
FoneLab for Android
Thanks!
FoneLab for Android
