Smart switch transfer double text message notifications
bama007
I purchased a S9 Galaxy. Using Smart switch I transferred all my data from the S7 to the S9. Everything is working well except now when I receive a text message, it will always show double the number of actual messages. I am using Message+ Went into phone and disabled everything on the standard message program only should be using the Message + APP. I'm very familiar with the phone along with fundamentals, this one has me stumped.
hi , are you in Verizon? Maybe long press the message+ app tap info>clear Data,cache then force stop see if it correct it
Yes I use Verizon, Message+ APP is primary chosen APP for text messages. Screenshot, one text message received and get a number 2 count. However, only one text message Screenshot_20190626-211023_One UI Home.jpg actually received
koltyn
