C cnorberg New member Sep 7, 2019 1 0 0 Sep 7, 2019 #1 i would like to know if it is possible to open a android expanded file stored on a sd card by a channel master stream+ dvr. i would like to access the content that the channel master stream+ stores on the sd card.
Rukbat Retired Moderator Feb 12, 2012 44,531 46 48 Sep 7, 2019 #2 What's the extension of the file? That determines whether you can open it in anything. (Phones don't open files, apps do.)
