Why does my N6 shutdown when I unplug my charger??
chullan88
3
Hi folks,
My N6 (LM48YI,XT1100 64GB ,5.1.1)which I bought from another guy seems to shutdown when I unplug it from the charger and then it won't boot properly.It would get stuck at the Optimising apps window and shutdown again.The only way to get it back to life is to switch on after plugging the charger.After this process,the phone also forgets all the stored Wifi passwords.The shutdown happens at other random ocassions as well.It seems the guy sold a dud piece to me..Tough luck..anybody facing the same issues??
Thanks in advance.
codeda
864
3
I would contact Motorola anyway. My friend bought a used one on swappa that had issues not too long ago. Contacted Motorola and they offered a replacement. That's a weird issue but it doesn't hurt to try and see what they say. Good luck!
smokedog87
