HTC U Ultra Display problem
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,684
4,840
113
This is less likely, but make sure there aren't any strong magnets near the phone. Devices that use magnetic sensors to activate a Smartcover function (i.e., turning off the screen when closing a smartcover) might react that way if there's a strong magnet right near the phone.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,684
4,840
113
Hmm. When you say it's a magnetic shutter, do you mean the cover stays shut thanks to a magnet, or do you mean that it's a smartcover that automatically turns off the screen when the cover is closed thanks to a magnet embedded in it? In either case, take the case off and see if the problem still occurs.
raimuell
5
Thank you very much, it was the magnetic shutter. Since I changed the cover, the problem is gone! Easy and perfect solution!
kevinrshay1984
