Android 10 for mate 20 pro
jeetu4444
Trusted Member
Sep 3, 2014
1,823
194
63
Hey guys today got stable Android 10 update on my Mate 20 pro...any of u ? build number 10.0.0.154
Security patch is 6th oct 2019
anu3682
Let me know if you're having wifi connection issue like me when updated to Android 10
on EMUI 10 beta I had some weird issues with wifi and cellular used simultaneously every few seconds causing timeouts while browsing files over my local network. But factory resetting and disabling Adguard apps DNS filtering fixed my issue.
frederickdawg
991
Oh, don't worry, you'll get used to that. :)
I've seen some people that have no problem with Gsam after Android 10. All of them have the 'more stats' options enabled through root or adb commands, though.
Yes, more stats are enabled or should I say were enabled Emui 10. Rolled back to 9.1 a few days back.all good.
Javier P
Ambassador
Feb 21, 2014
19,480
3
Mmmm, did you tried selecting Don't optimise for Gsam? I'm going to leave it that way for a day and see what happens. Not sure why I didn't try it before :(
