Android 10 for mate 20 pro
Hey guys today got stable Android 10 update on my Mate 20 pro...any of u ? build number 10.0.0.154
Security patch is 6th oct 2019
Here is the screen shot Huawei is faster than Samsung to stable build of Android 10
Let me know if you're having wifi connection issue like me when updated to Android 10
on EMUI 10 beta I had some weird issues with wifi and cellular used simultaneously every few seconds causing timeouts while browsing files over my local network. But factory resetting and disabling Adguard apps DNS filtering fixed my issue.
Accubattery pro and GSAM were the most evident that come to mind.
Yup. That was one of the first things I noticed on a different phone. Android 10 rendered those apps useless and I hope they manage to get them working again in the near future.
Sad as it sounds, I just cannot live without those two apps.
Oh, don't worry, you'll get used to that. :)
I've seen some people that have no problem with Gsam after Android 10. All of them have the 'more stats' options enabled through root or adb commands, though.
Yes, more stats are enabled or should I say were enabled Emui 10. Rolled back to 9.1 a few days back.all good.
Mmmm, did you tried selecting Don't optimise for Gsam? I'm going to leave it that way for a day and see what happens. Not sure why I didn't try it before :(
winarto
