Using bluetooth headset as wireless mic??
creatip
Hi there.
I'm using p40 pro and freebuds 3 I got from pre-ordering. Recently I'm into vlogging with my gf.
I want to use the freebuds 3 as a wireless mic, with the native camera app, but I can't seem to do that. The camera app always uses the internal mic, and I can't find the option to switch to the freebuds' mic.
I can do it with cinema FV5 apk, but we prefer the native camera app. I can use the beautify filter, and the image stabilisation is better on the native camera app imo.
Is there a workaround for this?
I'm on emui 11, and gms installed, if that helps.
Thank you.
czarka9000
