How to use Android Pay on LeEco Le pro 3?
homniaxor
Hi, I got a LeEco Le Pro 3 directly from China 8 months ago. Android pay just released in Canada and I want to use it.
But, When I open Android Pay on my Leeco Le Pro 3, it said : "Android Pay can't be used on this device - This may be because your device is rooted, has an unlocked bootloader or is running a custom ROM. As a result, Google can't confirm that your device meets Android Pay's security standards".
My phone isn't rooted! I checked it with some weird apps I found on the Play Store.
I do not have a custom ROM except if EUI is considered as a custom ROM.
Android Version : 6.0.1
EUI Version : 5.8.017S
Model Number : LEX720
Thank you for your support! :)
You are right, EUI doesn't satisfy Android Pay's Security Standards. I have a custom rom of EUI on my Le Max 2 and Android Pay works on that. Perhaps you can try that.
gruptysh
