Air command not working . Note4 . Marshmalo
I did something that someone said in other post about note 5 and marshmallow update having same problem, but it worked.
Go to settings - accessibility - Turn On both Vision and Hearing option...... Use it for few minutes .... WARNING - it's annoying as heck.... - than turn both of them OFF... And some how I got my action memo function back... Let's see how long it lasts......
Harsh
Harsh
This actually worked, thank you!
Harsh
Harsh
Great. Thanks a lot. This worked in my Note edge.
that is incredible it worked! Odd way to have a software flaw.
Saved me from a factory reset! Thanks for the tip!;)
Harsh
As odd as this solution seems to be. It WORKS!!! Thanks a lot!
Harsh
This reallyyyyyyyyy worked!!!!
Harsh
Worked on mine😃
Saved me a factory reset too! Thanks so much!
Which Vision and Hearing options need to be turned on? There are several in one of them. Just wondering as my Air Command isn't working. Trying to get it working again.
Harsh
Thanks dear. It really works. I was struggling from last 2 days. Finally its done as per your help.
siratguidance56
