G7 and fast wireless charging
johnnyshinta
2,666
22
So from what I understand the G7 does not support fast wireless charging. No biggie. My question is if I already have a cast wireless chargerike the 2018 Samsung one will the G7 negotiate the rate at which it charges and not see any ill effects?
Issemann
733
4
I've found charging to be inconsistent. For example, I have 4 older Samsung wireless charging pad. Granted, none of them are fast charging, but all should charge my G7. Except that 2 if them work and the other 2 don't. Not sure why that is.
Nubwy
526
I have the newest Samsung convertible fast charging pad. I can confirm it reduces the rate at which it charges to a slower spees. Will not charge fast. Takes almost two hours from about ten to fifteen percent to fully charged.
sjfrazier0410
23
I got a $10 wireless charger at Walmart yesterday. Even came with a quick charge 3 head and cord. It's a quick wireless charger too. No issues charging my G7. Didn't heat up, and worked like a charm. So shouldn't be a problem in terms of operation using a wireless quick charger.
Adam Matlock
Trusted Member
Jul 24, 2015
252
I just got an Incipio charger for my iPhone but it also works with other phones course. it is not fast at well with regard to charging the G7. Very slow
sjfrazier0410
23
Mine looks a little different but that's gotta be it. I know I said mine was wireless quick charge, and that was wrong, but it did come with the quick charge 3 head and wire. Mines worked great btw. I've noticed some worrying reviews there. We'll see.
https://www.amazon.com/dp/B07D21ZZ4...ag=hawk-future-20&ascsubtag=UUacUvbUpU6289569
That's the case I'm using. Works fine with the charger. Works best for grip with some protection, but not on the same level as a OtterBox or Spigen. But I have dropped it twice with no ill effects.
idon12no
474
My understanding is that, like the G6, the G7 does not support fast wireless charging. I don't care because I'm usually in no hurry when I use my wireless chargers, but I have a wireless charger that's supposed to be fast, and my G7 charges slowly. You guys got lucky if your phone charges quickly.
RandyRoyalty
