SchinkenSpicker
I hope as soon as the first V30s are out in the US we get more impressions on this. It's worrying. :/
Thank you for saying that!Just picked up the V30 this morning. Neither mine nor my wifes had any uneven color, weird horizontal banding, or uneven light levels (with hot spots) when the screen is set on low brightness in a dark room. I tried it with several different backgrounds including all black, all white, all red, all blue, and one with multiple colors.
This was my initial test. Just trying different colors in very low to an almost completely dark room.
I then downloaded the Display Tester app recommended by maxburn. Here are the results from that. This was in an almost completely dark room with the brightness setting on 1%.
Here's my reply in another thread using the app you suggested.
Is this a screenshot? If it is, it proves nothing as the issue is in the display...it would be like heading over to a photography forum and posting a pic from another camera and saying 'my camera works great', etc.
It can't be a screen shot....the phone is in the picture.
Yes, I've been told that several times already. But there's no way to show the screen without taking the picture with another device or camera. That in itself is a very flawed way as well.
No method is perfect, but your screenshot leaves out the panel, which is what we are referring to. We are looking for artifacts in the panel screen, and folks are attempting to show those artifacts using a picture. I appreciate that you are attempting to be helpful, but taking a picture of a screen while not perfect for sure, is totally more applicable than a screenshot that takes the panel out of the equation entirely. It would be more helpful if you simply stated that your screen tests perfect, rather than posting a screenshot that some folks might mistake for a picture of the actual panel.
I don't know about others but I took my V30 in to a pitch black room. Turned britenes all the way down. I'm sorry I do NOT see any problems. Tried different photos and screens. I did not look at an all red, blue, gray or any other solid screen. I would never need to do that.... Dauh...
I do not see the problems everyone is saying in this thread at this time.
My 2 cents. Lateck2,
I do have one horizontal band across the screen, brighter than the rest, but only noticeable below about 35% brightness.Glad yours is good. The problem doesn’t just appear on solid colored screens. I first noticed it when viewing white backgrounds with black font on news websites. Horizontal band across screen that was visible when scrolling. Very visible on the banding test using Display Tester app. Also the splotches / mura effect was very obvious when scrolling through news articles. The vertical banding was visible on any light colored solid background, especially gray, which didn’t happen on any Samsung GS 8+ I compared.
The rep I was with at the Verizon store even saw it and waived the restocking fee. He noticed it on the display V30 as well and we also compared side by side to a GS 8+. I didn’t exchange for another one, will wait and see if this gets resolved in later batches of phones.
You may be seeing some ghosting too, which LG should be able to help with software tweaks.
