Typing errors when using keyboard.
Rowacres
Hi Everyone
help required please. I have had my TAB-E for two years approx - its been brilliant in all respects.
Whilst typing yesterday, I noticed that what was being typed was being overridden by altered type.
The correct spelling was there to be seen, BUT, when (for example) I added a full stop or went for a new line some of the typed words altered into incorrect spelling.
No problems here as I am using my desktop PC.
I use WPS as my typing source.
Thanks in advance for your help
Welcome to Android Central! Moved this from the Galaxy Tab 10-inch forum (which is for the original Galaxy Tab) to the More Samsung Tablets forum (sorry, no dedicated Tab E forum here).
How often is this happening? It might be due to you inadvertently saving misspelled words. Try typing out a word that you know gets misspelled, and see if the misspelling shows up as a suggested word. If you see it there, long-press it, then look for an option to forget it.
Heritagesa01
