Open your Contacts app, select a contact that you want to make a Speed Dial, and tap the star at the top. This makes the contact a Favorite, and it will then show up at the top of the Speed Dial list.
I prefer creating a folder of Direct Dial widgets on the phone screen, because then I can just call someone with one touch. To create the widget, long-press any blank area of the homescreen, then select Add Widget, and look for the Direct Dial widget. Press and hold it, then drag it to the homescreen. When you release, it will ask you to select a contact for the widget, and also which phone number. When complete, just touching the widget will call that number.
You can then create a folder of Direct Dial widgets and call it Speed Dial. Just create more of the widgets, and make a folder, drag one of them on top of another. The folder will form, and you can name it. Then drag other Direct Dial widgets into it. You should be able to put 16 widgets in each folder.
