Moto G: Battery glitch?
Derek_78
5
I have a Motorola Moto G, had it for a few weeks and so far I am very happy with it, however.
This morning I turned it on, (yup off all night) checked my usual, twitter etc. Put it in my pocket and headed out.
Bit later I went to send a text and it was off? Turned it on to see 1% battery. I knew it was at about 50% battery earlier.
So I charged it for 5 min only to see it back around 50% as instant it seems as it depleted.
Glitch? Screen shot.
Derek_78
5
Re: Battery glitch?
Went fine after this. Now at 80% after flattening it and fully charging. I'll keep an eye on it tho.
jim1405
Active member
Dec 22, 2013
28
Re: Battery glitch?
You aren't alone. There is a thread over at the other site where a lot of owners have had similar flaky battery issues.
The same thing happened to me last night. Went to bed it was at 88% with everything turned off (Wi-Fi, BT, backups, updates etc.). 5 hours later it shut itself off. Powered it back up and it read 1%. Plugged it into a wall charger and 45 minutes later when I checked it was at 100%. Not enough time to fully charge to 100% if it really was at 1% to begin with. Flaky.
Harvinder Sunila
121
Re: Battery glitch?
I'm not sure it's a battery issue, I think it might be the cable and charger combination...I noticed while charging using an HTC cable and HTC plug it was fine, when I decided to try the cable supplied with the Moto G the charging icon would flicker several times as if on and off. I reseated (pulled out and put back in) the cable on both ends a few times and it seems to be ok now.
I just check when I plug it in that the charging icon is on, the "charging" text isn't flashing and the % icon is on.
baldpaul
71
Re: Battery glitch?
Same here too. Happened a few nights ago, went to bed with 50% remaining on battery. Woke up in morning and realised my alarm on the phone hadn't gone off and when I checked it had powered off. Turned back on to reveal battery on 1%. Started to charge it and after 30 or 40 minutes it was back up to 80-90%. Its been fine since and put it down to battery needing time to run through a few charge and discharge cycles. Glad its not just me anyway.
Sent from my Nexus 7 using Tapatalk
Reciprocal
104
Re: Battery glitch?
just happened to me after plugging the phone into my computer to transfer a couple things. from 75% to 1 instantly. charged it for about 30 minutes until the battery itself got back to full and the indicator went from 21 to 100%. Just a battery calibration issue, it seems.
neu smurph
158
Re: Battery glitch?
I had a different battery glitch on mine out of the box - OS not reporting via the API when the phone was plugged/unplugged. Fixed after Factory Reset. I'd recommend a Factory Reset before doing anything else on unboxing your new Moto G (should also fix the other common issue on the phone out of the box - inability to sideload apks).
Derek_78
5
Re: Battery glitch?
Just happened again. As you can see by my last post date it took a while to do this again. Link to other thread? What should I do? Any fixes?
shmotog
133
Re: Battery glitch?
Did you say wall charger? I charge mine on the PC.
baldpaul
71
Re: Battery glitch?
It happened to me twice so I contacted Motorola UK and they suggested 2 complete discharge (until it turns itself off) and recharge (back to 100%) cycles. After the second charge and with the phone at 100% charge it turned itself off again but when I turned it back on it wasn't showing 1% charge (which is what it had done previously) but still 100%. It hasn't happened since and the phone is now on 4.4.2. It was on 4.3 when I had the power offs. On the first 2 occasions that I had the problem Moto Assist was "active" i.e. in sleep mode so I have stopped using it for the time being and will try again in a few weeks if the phone behaves itself. Each time I have had the problem the phone has not been charging and has just been sitting there with the screen off.
aspot72
188
Re: Battery glitch?
Any charge source (PC or wall) btwn 0.5mAh and 1.5mAh is OK. (info from Motorola's website). Only thing is that lower mAh's need bit longer charging time (30-45 mins extra).
However, I noticed that lower input, despite longer charge time, keeps battery last longer... I charging my MotoG with either LG charger (0.75mAh) or HTC charger (1.0mAh) and all ok...
Nicole Summers
Active member
Nov 20, 2013
26
Re: Battery glitch?
Hey all,
As far as I know the Kitkat update applied changes to the battery meter. A full charging cycle (0% to 100% and then +1h on 100%) should help.
Cheers,
Nicole
anon(847090)
6,655
31
Re: Battery glitch?
This is more of a software issue and it happens when you update the OS.
The fix is to completely drain the battery(let it die) and then charge it to 100% that will recalibrate the battery
shmotog
133
Re: Battery glitch?
theres a reason motorola gave only a usb cable with it. you're meant to charge it from a computer or laptop usb port. chargers can be used but i would get one that gives out same current as a usb port does.
aspot72
188
Re: Battery glitch?
Very few chargers with 500 mAh...
Sent from my XT1032 using Tapatalk
Caz42
Active member
Jan 10, 2014
35
Re: Battery glitch?
I've had the same issue twice. Had 60% battery which went to 8% over an hour period with phone on standby only. When I plugged wire in to charge it, it went straight back to 60% within a minute of charging ??
I charge mine slowly with a 500 wall charger and get 4 days medium use from the phone, 2 days heavy use, and around 5-6 days light use.
Caz42
Active member
Jan 10, 2014
35
Re: Battery glitch?
Presently while charging, my phone doesn't play a tune/beep to tell me when it's fully charged. Is there a setting for this I've missed somewhere as it's annoying me having to keep checking?
alexpall
