anon(19981)
Re: Trouble Activating on Verizon?
Yes. I believe that should work. Just be careful which adapter you use. A cheap one might screw up your current phone while removing it.
Well duh! Sometimes I crack me up! Thought I had figured out in my mind how I was going to get this all to work with no snags on Verizon, but maybe there's an easier way for me to go from my current micro sim to a nano sim.
If I take the new nano sim, put it in a nano-to-micro adapter in my current phone, then update online as itguyjax8430 suggested, the new nano sim should be ready to go in my MPXE (if it ever arrives *sigh*). Yes?
Am I correct (as Scratch4 & djh2011 mentioned) that the adapted nano sim should already be in my old phone (and the old phone turned ON?) when I do the online change?
So, then if all that goes as expected, what happens when Moto & Verizon actually DO get together with the correct MXPE imei numbers after I've entered online the imei of my old phone? Will Verizon's system automatically update the old imei to that of the new MXPE?
Apologies for all the questions, but I can't be without a phone, & I only want to do this sim thing once.
(Verizon, why do you have to make life so difficult???)
