why do the cases have the 2 holes at the bottom?
So they don't block the microphones on the back?
I've got half a dozen or more cases & keep coming back to the Cruzerlite Bug Droid case.all the above are good but my vote is for Cruzerlite, the blue is nice !!
http://www.amazon.com/s/ref=nb_sb_s...ag=hawk-future-20&ascsubtag=UUacUvbUpU4207658
you can also head over to youtube and search for cruzerlite case for droid turbo by rootjunky, he reviews the case and you can see what it looks like on the phone in the video.
can anyone make a direct comparison to the thinness between the diztronic and the cruzerlite cases?
When I first got my Turbo on Halloween, the options were considerably fewer than now. It was also less clear that some cases didn't fit both BN and MG versions of the Turbo (all the Verizon cases fit both).
So, the first case I ordered was the black X version Cimo directly from China. It turned out was for the MG version and I have the BN Turbo. It didn't fit (sides are too short).
I bring it up because I was very impressed with the quality and look of the case. I don't like the S design Cimo, but the X was pretty cool, although I do prefer a plain black.
I would recommend it highly, especially since you want the thinnest. Note that I too had a Feather shell for my Droid Maxx and I hated it. I couldn't see the point of using it. I do like the slimmest I can find, though and have historically used a silicone skin of some sort as my main case.
Beyond that I have both a black Tudia and a red Diztronic and they're both very nice. They seem to me to be about as thin as you can get. Definitley less bulky than an Otterbox Commuter or even the Verizon glossy silicone case (I have one in black), for example.
My guess would be the thinnest/lightest would still be a silicone gel skin, but they seem to have gone away to a large extent.
Is the Diztronic thinner than the Cimo? Is the X pattern Cimo the same thickness as the S shape?
What does that have to do with the thinnest case available?I have had this phone for a week and I love it. The battery lasts all day and it has Kit Kat 4.4.4 with Lollipop coming within the next week or two.
i considered the cruzerlite cases because i like having the cutouts but i didn't like the android logo on the back.
Just found this on Amazon. Seems like it is a similar case to the incipio feather that i had for my maxx. I have the ballistic nylon model and says it doesn't fit but may try it just incase.
One of the reviews says it does(for what its worth)Great find. It lists the case as being 15g. I weighed my Diztronic at 28g. I think I'll try one of the blue ones. I hope they have a good non-slippery feel.
