I have a droid turbo and it is stuck in ap fastboot but rsd lite won't detect it so how would I flash an xml file to it to restore the firmware?
There are several Flashing options, but you need to install official Motorola Drivers for any of them to work.I have a droid turbo and it is stuck in ap fastboot but rsd lite won't detect it so how would I flash an xml file to it to restore the firmware?
All of what?I have tried all of them and they either don't flash the stuff I need or they just flat out don't pick up my device. Fastboot or mfastboot won't flash anything and rsd lite won't even detect my phone
Good, how is it listed in Device Manager?
I don't think that it should say composite
Try uninstalling the device and driver
Reinstal drivers reboot
Sent from my XT907 using Tapatalk
Mot adb interfaceWhat should it say then?
Good, which file are you trying to flash?
