I want to map a walking route but can't find an app that will let me create the route on the map. Any suggestions?
1. Open a email account
2. Click left menu button
3. Select Email Settings
4. Select Default Email Account option
5. And select account name to change default
Looks like this may only work on the regular email accounts but the gMail account appears to not show this but try the option above in the regular email account and see if it still shows the gMail accounts in the list. Maybe it will still work...
I found something absolutely hilarious!!
1. Go to the native text app and open a converstation (any will do)
2. long press one of the text message bubbles.
3. The third option (Copy messsage text), is spelled wrong (Really?!?!)
Thanks open source software!
tip: How to get browser to word warp (resize to fit screen in portrait) so you do not have to move screen left to right to read
pinch to zoom to your desired text size, turn phone to landscape and then back to portrait, takes a couple seconds to resize.
Works with stock browser and Dolphin HD have not tried with skyfire or Opera.
If you don't want Facebook contacts in your contacts, and you don't want to worry about any of the problems that have been plaguing people with the default Facebook app, then just get "syncmypix" from the Market. It will look at all your Facebook friends and try to match them with your contacts (if they have the same name or phone number) and then replace that contact's picture with their Facebook profile pic. Once it finishes syncing, you can manually link contact pictures with contacts if their Facebook name is different from their name in your phone contacts. Syncmypix just gets you the pics, of course; you'll have to use the facebook mobile site to actually look at statuses and comments and such, but it sounds like syncmypix does everything you want and nothing you don't!
Just found out that you can get the "desktop toggles" add on in the market to do this easier...when browsing hit menu>toolbar to bring up the icon.
didn't work for me
So in doing this, do I:
- Remove Facebook from "My Accounts"?
- Do I need to have the Facebook app (from the Market) on my phone?
I don't have the Facebook app on my phone, but I did link my Facebook account to my phone, so all my Facebook friends show up in there.
If I don't have the Facebook app then how would it be able to look at my Facebook friends?
Just wanted to clarify these things before I proceeded.
Figured I'd ask this here instead of making a new thread:
Where should I put videos, on the SD card, so that they show up so I can play them? The video in question is a .MOV file if that makes any difference. I have a .3gp video in the camera folder and it shows up fine but the .MOV file does not so up...Any help wold be greatly appreciated.
The battery app is called Battery Status Pro, the icon can be seen right in his pic.
Screen shots are possible if you root, not sure without (yet).
Tip: The Verizon official screen protectors are absolutely horrible and make the screen blurry. Every time. Every one I've used for the X
