Speaker phone issue
kbz1960
561
35
28
Hi, looking to see if anyone else was having an issue with the speaker phone only. While on a call using speaker phone either the other party tells me that I'm cutting in and out or I have to tell them that and when I shut off my speaker phone everything is fine on both ends.
If they shut their speaker phone off it doesn't help. I tried with my mom's phone, different mfg, and no issue either way when my phone isn't being used.
Maybe a noise canceling mic issue?
dangerousfen
570
48
28
I had that issue and not only with Nokia. It usually happens when I call my sister on her landline and she switches on the speaker phone at her end.
I get the feeling it's a network issue and nothing to do with the phone.
kbz1960
561
35
28
Haven't had a chance to check sage mode yet but only happens when using my phone. Same network different phone and it doesn't happen.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,755
113
Do you mean it doesn't allow you to boot into Safe Mode, or that you can't use any of your 3rd party apps in Safe Mode? If the latter, remember that this is just a troubleshooting step, not a suggestion to run the phone in Safe Mode constantly.
kbz1960
561
35
28
I have no access to Verizon in safe mode. It comes on with airplane mode on.
This is what I get when I do it and then turn airplane mode off.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,755
113
That's odd -- you should be able to turn off Airplane Mode in Safe Mode. Is the toggle greyed out?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,755
113
I've never seen a phone not able to connect to the carrier in Safe Mode. What happens if you remove the SIM and reinsert it?
kbz1960
561
35
28
Tried my mom's phone in safe mode, different brand, same carrier. Hers works fine after turning airplane mode off.
Got a new SIM card ordered.
kbz1960
561
35
28
Haven't got the new SIM yet but the same SIM in a moto g power has no issue with speaker phone and the signal by dbm is better.
Safe mode can also make calls etc on the moto.
kbz1960
561
35
28
Alright. New SIM no difference on any of it. I like this motor g power better anyway.
Must just be something going out in the Nokia.
