[ROM][PORT] SlimBean 3.10 updated 1-21-14
kenharkey7
222
18
This came about cause I just decided to take a break from Paranoid Android and looked to see what else I could port.
This is slim bean 3.1.0 based on jelly bean 4.1.2 and ported from the Optimus L7 using phenom's cm10 rom and includes the latest camera patch.
Thanks to:
  • Phenom for CM10 for the Elite
  • tudorsirb for the slim rom for the L7
  • The slim team
  • The cm team
  • google
  • and last but certainly not least, all of you
# What Works:
Everything that works in cm10
# What Doesn't Work:
Slimbean ota (will likely never work, will try to remove the option in the future)
Torch
Whatever else that doesn't work in cm10
# Minor Annoyances:
Shows 1x instead of 3g but still has 3g connectivity
Install instructions:
  • wipe data/factory reset
  • flash rom
  • flash slim-gapps
  • reboot
  • wait
  • Enjoy
If you are coming from a previous version of slimbean you do not have to do a full wipe, just wipe cache and dalvik cache and flash the new rom, if you are coming from any other rom a full wipe is recommended.
Changelog:
1-16-14 Initial release
1-17-14 Fixed storage to allow both emmc and sdcard to mount, removed boot to bootloader option
1-21-14 Small maintenance work, fixed torch and small graphical issues
## If you have any issues with the play store not updating use regular cm10 gapps
All Slim stuff is now here
http://www.androidfilehost.com/?w=files&flid=12188
Here is the default slimbean wallpaper
dcleiter
Re: [ROM][PORT] SlimBean 3.10
I just installed this. Thank you so much for all of your work! This is an awesome ROM! I love the ability to customize the lock screen and I like the overall UI. I did have one question, I am having trouble playing media through a bluetooth headset. I can talk on the phone through bluetooth fine, but when I try to play Pandora or a video, it just plays through the phone. Is anyone else having that problem? I did not see where the CM10 issues are displayed so I was curious. I did a full wipe of all of the caches and the factory data reset. I am not sure if it is an issue from another ROM I installed or not. It did start when I had another ROM installed. I think it started the CM9 posted in these threads or Phenom's Jelly bean ROM. Thanks
vollmerman
Thank you for this rom I flashed it yesterday and works great .I currently use the elite only as a backup phone my primary phone is a galaxy reverb. The question I have is do you think you could port this rom to the galaxy reverb ?
Sent from my SPH-M950 using Tapatalk
LarabelMike
First off thanks for the rom! Fast, smooth, and the coolest looking one I've tried so far. I noticed that my voicemail isn't working. anyone else have this problem? It could be something I did... not a big deal....probably get 1 voicemail a month:p When I call the voicemail it goes to a virgin mobile automated service but doesn't have a option for voicemail setup or anything. I tried long press #1 and *86 and get the same recording. I've only had your rom for a couple days and haven't noticed anything else, other than it's SWEET!
xerenx
6
Installed 3 times and re-downloaded once, the VM696 stays loading at the Slimbean loading animation. This is the first ROM I've tried and I don't think it is going to work for me. Unless there is a bootlog I can access to show where the system init is hung up at.
xerenx
6
I did a wipe/factory reset and it worked. I also did a wipe/factory reset before I flashed the slim zip.
Thanks for the port.
xerenx
6
This mod breathed new life into what I thought was really crappy phone that I couldn't stand using. It's actually quite nice now.
It hasn't solved the problem of this phone being stuck in 1xrtt speeds(ongoing issue since day 1), but the performance is 100% better. I'm really impressed with this ROM.
Beej30
4
I'm running into an issue. I'm new to this so if I'm missing something easy and obvious I apologize in advance. After getting the file on the SD card I couldn't get recovery to recognize the file unless I renamed it to update.zip. Once this was done I was able to start the install but I get a signature verification error and it aborts the installation. Screen shot included. Also, as the screenshot shows, I only go to the stock recovery screen. I installed ROM manager but I don't think it's working right. When I reboot to recovery from that software it just boots to the stock again. Any thoughts on what I'm missing?
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
The OP mentioned that you should still be getting normal 3G speeds, despite it showing 1X in the status bar
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
You said you were using stock recovery? You need a custom one like TWRP or CWM in order to be able to install custom ROMs
Beej30
4
But that's my problem, I'm running Rom Manager and it still comes up stock. TWRP is part of that. I'm think it's just not compatible. I'm going to try another app.
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
ROM manager only works if you have TWRP installed. An app alone can't install the ROM
Beej30
4
Thanks for getting me moving the right direction. I couldn't ever find a TWRP for Optimus Elite or for anything gingerbread. I finally found giantpune's CWM instructions and download and I'm finally off the stock recovery. Thanks to this great forum I'm running a better phone!
AmeliaRodriguez
