Liquidplacidity
The battery hasn't yet increased. its still worse. They is two option to increase the battery life....One is to put the phone in Airplane mode when not in use. That's what i do. Second is to dial *#*#4636#*#* Phone information. Scroll down. Select CDMA only. Turn off cell radio, wait a couple seconds. Turn cell radio back on with same button. Exit with home button. Turn airplane mode on, then turn it back off. Note its only a work around to fix cell radio bug . And you only going to get 1x instead of 3G... when you choose second option
Lol you copied and pasted from my post. I tried to make an app to do it for you but can't figure out how to scroll through the menus.
