Mellimel22
Banned
How do you switch to 1x and still get emails?
Two ways that I know of.
A) Go into settings and select "Wireless and networks"
Scroll down and select "mobile networks"
Select "CDMA Network Preferences" and click on "CDMA only"
B) Head straight into the dialer and type this in without quotations "*#*#4636#*#*"
Select "phone information"
Head down to where is says CDMA auto(prl) and click it
You'll have a bunch of choices but make sure to select "CDMA only"
Done
PS: Sure it's slower, but tolerable and doesn't bother me at all. (As if our 3G is a miracle anyway), but yeah doing these steps and then overclocking my phone is probably the best optimus v experience
You'll notice your battery lasts longer
I tested using 1x for about half a day to see if it improved battery life, it doesn't. If anything, it gets worse. The drain level is still the same (1% per hour if you aren't doing anything and aren't in an area with poor reception), but actually trying to do something just takes longer. It seems like keeping the screen on is what kills battery the most for me.
I've had a low of 2 hours, high of 36, been using Harmonia 2 for about a month now.
1-1.5% per hour is the lowest you can ever get it, the hardware simply needs x amount to run.
Look into the Anker batteries on Ebay, you can pick up another 15-20% from that for about $10.
Harmonia 1 will give you even longer battery (probably the longest of any rom), but like I said, you are nearing the hardware's minimum needed to keep running.
Are you referring to the 1600 or 3200 mAh version?
obviously the 1600 is like 9 bucks.
