made some edits to the boardconfig.mk (wifi changes) and im running a build now. wish me luck
I haven't done any git, the vendor files are bobzhomes ics and the device files are modified bobzhome ics. Its not the kernel, I've tried different kernels. I've switch the wireless.ko in system/lib/modules with the one from the rom I pulled the boot.img from. The reason it wouldn't turn on is because the build.prop had it set to eth0 instead of wlan0. Now it will turn on, it just wont pick anything up.
#Wifi
WPA_SUPPLICANT_VERSION := VER_0_6_X
BOARD_WLAN_DEVICE := bcm4325
BOARD_WEXT_NO_COMBO_SCAN := true
BOARD_WPA_SUPPLICANT_DRIVER := WEXT
WIFI_DRIVER_HAS_LGE_SOFTAP := true
WIFI_DRIVER_MODULE_PATH := "/system/lib/modules/wireless.ko"
WIFI_DRIVER_MODULE_ARG := "firmware_path=/etc/wl/rtecdc.bin nvram_path=/etc/wl/nvram.txt config_path=/data/misc/wifi/config"
WIFI_DRIVER_MODULE_NAME := "wireless"
WIFI_DRIVER_FW_PATH_STA := "/system/etc/wl/rtecdc.bin"
WIFI_DRIVER_FW_PATH_AP := "/system/etc/wl/rtecdc-apsta.bin"
BOARD_SOFTAP_DEVICE_TI := bcm4325
# Wifi
PRODUCT_COPY_FILES += \
vendor/lge/VM670/proprietary/system/etc/wifi/wpa_supplicant.conf:system/etc/wifi/wpa_supplicant.conf \
vendor/lge/VM670/proprietary/system/etc/wl/nvram.txt:system/etc/wl/nvram.txt \
vendor/lge/VM670/proprietary/system/etc/dhcpd/dhcpcd.conf:system/etc/dhcpcd/dhcpcd.conf \
vendor/lge/VM670/proprietary/system/etc/wl/rtecdc.bin:system/etc/wl/rtecdc.bin \
vendor/lge/VM670/proprietary/system/etc/wl/rtecdc-apsta.bin:system/etc/wl/rtecdc-apsta.bin \
vendor/lge/VM670/proprietary/system/etc/wl/rtecdc-mfgtest.bin:system/etc/wl/rtecdc-mfgtest.bin \
vendor/lge/VM670/proprietary/system/etc/firmware/wlan/cfg.dat:system/etc/firmware/wlan/cfg.dat \
vendor/lge/VM670/proprietary/system/etc/firmware/wlan/qcom_cfg.ini:system/etc/firmware/wlan/qcom_cfg.ini \
vendor/lge/VM670/proprietary/system/etc/firmware/wlan/qcom_fw.bin:system/etc/firmware/wlan/qcom_fw.bin \
vendor/lge/VM670/proprietary/system/bin/wl:system/bin/wl
also the system/vendor/lge/vm670/vm670-vendor-blobs.mk should include this for the wireless proprietary files to copy over:
Code:# Wifi PRODUCT_COPY_FILES += \ vendor/lge/VM670/proprietary/system/etc/wifi/wpa_supplicant.conf:system/etc/wifi/wpa_supplicant.conf \ vendor/lge/VM670/proprietary/system/etc/wl/nvram.txt:system/etc/wl/nvram.txt \ vendor/lge/VM670/proprietary/system/etc/dhcpd/dhcpcd.conf:system/etc/dhcpcd/dhcpcd.conf \ vendor/lge/VM670/proprietary/system/etc/wl/rtecdc.bin:system/etc/wl/rtecdc.bin \ vendor/lge/VM670/proprietary/system/etc/wl/rtecdc-apsta.bin:system/etc/wl/rtecdc-apsta.bin \ vendor/lge/VM670/proprietary/system/etc/wl/rtecdc-mfgtest.bin:system/etc/wl/rtecdc-mfgtest.bin \ vendor/lge/VM670/proprietary/system/etc/firmware/wlan/cfg.dat:system/etc/firmware/wlan/cfg.dat \ vendor/lge/VM670/proprietary/system/etc/firmware/wlan/qcom_cfg.ini:system/etc/firmware/wlan/qcom_cfg.ini \ vendor/lge/VM670/proprietary/system/etc/firmware/wlan/qcom_fw.bin:system/etc/firmware/wlan/qcom_fw.bin \ vendor/lge/VM670/proprietary/system/bin/wl:system/bin/wl
Could you post this file/. And help seller find a fix, also the camera preview would be nice just a suggestion
Because CNA its the Rom!!
Would the wifi fix zip on xda work?
http://forum.xda-developers.com/showthread.php?t=1445766
Sent from my VM670 using Tapatalk 2
Yo sellers don't know if this has been addressed but I didn't see no music player I need my player side note I can get my own which I did aside that and the known bugs which I know your on your way to fixing can't wait and drews touch recovery works with this. thanks for the hard work
[APK] WiFix - Fixes regional Wi-Fi problems in IceCream Sandwich - xda-developers
Nope failed status0
Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
Well then you would have to install the apk by itsself. But it wouldn't work anyways because there is an edit that needs to be made in the build.prop
Hmmmmmmmmmmmmmm
