Ladies and gentlemen, I am at a loss...everytime my phone reboots, it cycles through the factory reset where it says (in yellow script) to not pull out the battery, formatting data, formatting cache, etc...
THE GOOD:
-I have jerryscripts BACKside IHO Cyanogenmod Rom flashed and it will load, though everytime I reboot, I start all over, but I can get to everything; market, file managers, terminal emulator
-I can access the phones through ADB
THE BAD:
-tried every method I've come across so far in the last 8hrs STRAIGHT!!! cannot get into fastboot to make any repairs that call for the 'blue screen'
-tried to flash_eraseall /dev/mtd/mtd8, but the flash_eraseall file could not be found
-tried to flash the xionia recovery through terminal emulator with root access (which worked for me before when I was having problems rooting)
-ROMtools claimed to have flashed the xionia recovery, but when it rebooted, it simply went back through the factory reset and then loaded up BACKside IHO
I'm getting sick of going through the first boot setup on the rom, not to mention not being able to save anything I set up on it since it will be gone next time I reboot.
Is there any way to kill the factory recovery loop from the rom? ADB? Any way to push the right flash_eraseall file to where it needs to be to take out the /dev/mtd/mtd8 file that seemed to work for a couple other people?
I'm running Windows 7 64-bit and have all the propoer LG drivers installed and functioning properly.
I also have two Clockwork backups on my sd card if there is a way to load one of those from the rom or adb. One is the stock Froyo build (rooted) and the other is my first setup for the BACKside IHO rom.
