getbretweir
Banned
Re: Nexus 6P or Note 5?
I'd get the 6p regardless, unless the pen is worth the extra $200 to you, but yeah, if you plan on keeping it for a significant amount of time (I'd say 2 years instead of 3) then I'd definitely recommend the 6p. In addition to updates, TW would tire on me, and it wouldn't be unheard of for a Samsung phone to experience a bit more lag after 12-18 months, though that remains to be seen with the Note 5.
If you plan to keep it for 3 yrs get the 6p I have the Note 4 now and you'll quickly get tired of waiting for the next os update.
Plus you'll most likely only get 2 updates with the Note 5. The 6p should be updated for the next 4 yrs or so.
