Hi, I have a few questions on this process. I read the guides and just want to confirm a few things....
When I flash this recovery image I do the following steps:
1. Save the zip file to a location on my Windows PC
2. Plug phone into PC and be in fastboot
3. Use cmd prompt to change to the directory where the zip file is
4. Use cmd prompt to flash via fastboot
Questions are:
1. Is this correct?
2. Does it matter where I save the zip file (does it have to be in the same folder as the files I used to unlock the bootloader?)?
3. Once this recovery image is flashed on my phone, does it replace the stock recovery file on my phone (just overwrite with same name, or should I name the Amon Ra file something different)?
Thanks for any help with these questions.
Questions are:
1. Is this correct?
