Where did you see that it is supposed to get 9 hours?
I found this on Samsung's site: Samsung Galaxy Note? 10.1- 2014 Edition (Wi-Fi), Black 16GB
[h=4]INTERNET USE TIME[/h]WiFi: 9 hours
- [h=4]BATTERY, STANDBY[/h]Up to 2537 hours*
- [h=4]BATTERY TYPE AND SIZE[/h]Li-Polymer, 8,220mAh
- [h=4]MUSIC PLAY TIME[/h]Up to 122 Hours*
- [h=4]VIDEO PLAY TIME[/h]Up to 10 Hours*
And I found this further down the page:
*Results are based on lab environment testing. Refer to your network carrier?s website for network specific talk times.
Where do you get 3 hours from?
I get around 7 hours screen time. A 44 minute video chews up 9-10%, so that would correlate to 450 minutes or 7.5 hours. If you're only getting 3 hours screen time, either something is wrong with your tablet or you're using 100% brightness. I use 20% brightness and it looks fine.
2 small details:
1) This didn't last 3 hours. Considering that there's still about 30% of battery left, it should last in total 4h30min, with the same kind of use you had before
2) I've read that the ipad turns off wifi during sleep. Therefore to be comparable, you might want to check the Note's option of turning off wifi when the screen is off.
Wifi 9 hours.. Tbh this thing lasts 1/4th the time as me iPad air which is disappointing
Sent from my SM-N900T
The key phrase being lab environment testing. Meaning fast wifi, lowered screen , etc. Also what isn't known is how they accomplished the time achieved for video. It could have been a 10 minute video on a loop played until the battery died, with all radios off and low brightness.
Then you should compare it against 9*0.7=6.3 hours, not the 9 advertised.I plug in my stuff once it hits 30% so effectively only 3 hours
Two problems in this line:Read? I've used an iPad and your wrong.
iPad does keep wifi on when on stand by (screen off)
Can you get a source for that? There are dozens of forum posts of users complaining of exactly the opposite in the link I provided
BATTERY, STANDBY
Up to 2537 hours*
That is 13 weeks?
If I get 4 days on standby without the battery going dead flat I am lucky.
I sold a 4th Gen iPad to buy the Note 10.1 2014 and am very disappointed in the battery life in comparison.
I used to have the ipas next to my bed. I'd do some light surfing before going to sleep then leave the iPad on standby until the next night. I could easily go on like this for a couple of weeks.
With the Note 10.1 I have to tun it off completely each night. It's a joke :-/
