Will the Note 10/10+ have RCS support on either Samsung or Android Messaging apps? Unlocked or carrier branded.
Asking for a friend.
No it's not built into the Samsung message app , it's your carrier that's doing it.I have it on my Note 9, my moms S9 and my dads S10. I think its built into the Samsung messaging app.
Google message app should be doing this soon though.
I definitely agree, but my note 9 on Att or TMobile on unlocked firmware no RCS and when I flash to carrier one it has it , so leads me to believe that Samsung app itself don't support it .It requires both carrier and app support.
I agree, Google supposed to make their messaging app global RCS soon to fix this , but still haven't seen it on my pixel phones , once it happens all my phones will use Google message app. I do like Samsung version a little more but until something changes .RCS sure seems to be a cumbersome, confusing and disappointing solution to a seemingly simple problem.
Read receipts and can see the other person writing back to you while messaging themI use Google Messages in the US. How can I tell it is supporting RCS?
But that only works if the other person is using an RCS supported app, right?Read receipts and can see the other person writing back to you while messaging them
Yeah ..But that only works if the other person is using an RCS supported app, right?
