I've heard some have concerns due to it being on all the time and affecting the battery.
Do you keep it on all the time?
Yes under setting look for power saving just uncheck it.Is there a way to turn it off? I personally like this feature.
It is actually under Battery in settings not Power SaveYes under setting look for power saving just uncheck it.
There's nothing that says battery.It is actually under Battery in settings not Power Save
Lol. OK so yours says battery.If you go under settings and scroll down near the bottom you should be able to find it.
I actually don't even charge my phone. I just swap out the battery. However this morning I was at 20% and wanted to save my full battery since I was going to work, so I tried fast charging. Went from 20% to 68% in a little less than 30 minutes. Awesome.
From my smokin' hot Note 4
Whereas mines only says powersaving.
I'm not understanding what the issue was
I can find the battery stats. It's under powersaving.Most should be the same -- So not sure why you can't find the battery stats within your settings. It is a standard area for all Android phones.
And from the sound of it not all are the same. If I could post a picture I would. But I'm one away from being able to post em
I have sprintJust curious -- Which carrier do you have?
