Battery life is poor now
Closingracer
Banned
Apr 5, 2012
3,033
And with like 48 minutes if screen time
Sent from my SM-N910V using Tapatalk
LaTuFu
817
Take a ss of the stats for the time line. The one that you get if you tap the time graph.
My first reaction is it may be a new app you downloaded or one you used for the first time today.
I had the same problem earlier today. Turned out to be an app I used.
theoretically
176
htc evo 4g
330
5
Do you charge your phone every night or only when it gets low?
Also, when you do charge, do you set it to Fast Charge or normal?
LaTuFu
817
It looks like it is a combination of some app of yours is waking up periodically and running in the background, and you were in an area with weak signal for an extended period of time. That will make the radio spin around looking for a better signal, which will run down battery. Is that normal use for you, or were you traveling to an area you don't normally go to on a daily basis?
Closingracer
Banned
Apr 5, 2012
3,033
I get about 2-3 bars at work and at home
LaTuFu
817
Hmm. About the same as me. But your graphic is showing much lower than that during some parts of your day.
LaTuFu
817
What kind of work environment are you in most of the time? Around machinery generating a lot of EMF? An office environment? Retail floor?
ImTheDuke
Active member
Jul 13, 2010
36
I've had the same problem with mine. I had the same problem with the Note 3 as well. With the Note 3 I noticed a drastic loss of battery time after a T Mobile update. I ended up doing a factory reset and that cured it. After a few weeks with the Note 4 the same battery drain started happening.This time there was no update that I could tell. Did some tweaks to try to help but ended up doing a factory reset and again, that totally fixed it.,
Closingracer
Banned
Apr 5, 2012
3,033
That's so much work lol guess I'll do it
tx_tuff
2,029
28
Probably an app, something is keeping the phone awake even while the screen is off. Just checked my battery stats and my phone is pretty much only awake while my screen is on
Here's mine with 3 hours screen on time
His shows 12 hours and 55% yours is 10 hours and 55% also, so his is acutely better then yours.
