Battery life is poor now
I've had the same problem with mine. I had the same problem with the Note 3 as well. With the Note 3 I noticed a drastic loss of battery time after a T Mobile update. I ended up doing a factory reset and that cured it. After a few weeks with the Note 4 the same battery drain started happening.This time there was no update that I could tell. Did some tweaks to try to help but ended up doing a factory reset and again, that totally fixed it.,
That fixed it because you wiped the app that was probably causing the issue. Did you reload all of your apps since the reset?
My guess is you've wrecked your battery by only utilizing fast charge...but that IS just a guess.
No chance. I don't think Samsung would have put the option on the phone if the technology didn't work better than that.
From like 1 yesterday till now
Sent from my SM-N910V using Tapatalk
Yeah it looks like whatever mobile network issues you had the other day are gone.
It's probably between home and work since I didn't go to work yesterday lol
Also it seems the awake issue solved itself so I am assuming it's an app that requires a steady internet connection? It still does it and those in the middle where I never turned it on was when I was sleeping . Might do a fresh reboot though
Ph4
