DCM Provider Android Lollipop :: Battery Drain
NeilWhitear
49
Hi.
Does anyone know what DCM Provider does?
My Note for with Lollipop is suffering badly from battery drain (19%) recent charge from this app.
I have tried restarting the phone to no avail.
Help please?
tcole16
3
Not sure what exactly it is, but I found a youtube video that had me go to my settings.
Settings - Apps - All - DCMprovider - Force Close then Clear Data
Then it should work for you!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,670
4,813
113
It's hard to find anything about it, but from what I can gather, it has to do with wi-fi. I found this little nugget in a firmware FAQ from Actiontec, which makes Screenbeam, a wireless display:
(Q) What is DCM?
(A) DCM stands for Different Channel Mode. DCM is a function of the wireless network adapter and its driver. It enables the system's wireless adapter to simultaneously operate multiple connections on different wireless channels, and supports applications such as Wi-Fi infrastructure and Wi-Fi Direct.
However, this doesn't mean that I know for sure why DCM Provider is causing problems. I'd suggest a cache partition wipe to start with, which won't erase any personal data: https://support.t-mobile.com/docs/DOC-28932
