How to activate flashlight shortcut on lock screen
Mecomug
Active member
Oct 11, 2014
36
Just done the lollipop update and have been reading about how there would be a flashlight button on lock screen and in notification bar. I don't have it and can't seem to find where to put it on. Does anyone know how to do it?
It looks like a lot of people are missing it. Check out this thread Flashlight.
You can also give this a try, it worked on my Note 4 before I rooted it and used Wanam Xposed to enable it.
[HiDDEN SETTING] FLASHLIGHT volume-up long-p… | Samsung Galaxy S 4 i9500, i9505, i9505G, i9506 | XDA Forums
Download clicklight in the playstore. The only permission it needs, is to access camera (to turn the light on). It's the same permission your stock flashlight widget uses. Anyways, once installed, just press power to wake the screen, then double tap the power button. Same for turning it off. Enjoy
thanks, this works quite well
thanks this is the best solution I've tried yet...
Also you should be able to swipe down your notification shade while the phone is locked. I do this all the time to use the flashlight.
kctraci1
