ScottJ28
Active member
Got hot with the initial smart sync, but cooled down quickly and no problems with fast charge. Running great so far.
I don't have a Note 7... Yet (trying to sweet talk my wife into letting me use her upgrade) but my S7 edge/Note 5 did this for the first couple of days and then things settled down.Anyone finding it runs very warm to hot even after setting and syncing it?
Also find thst it doesn't fast charge with Supplied cable and USB fast charge Plug.
If everyone only knew what they know now, lolI called the battery running "HOT" back on August 18th!
Well were under recall so maby turn off or trade in to avoid a possible more serious problem.Anyone finding it runs very warm to hot even after setting and syncing it?
The post you quoted was from the Aug 18th, the first day alot of people received their devices.... The thread was brought back up because a lot of things make since now and some called heat issues on day 1Well were under recall so maby turn off or trade in to avoid a possible more serious problem.
Its almost sublume to post heating issues durring a battery recall
Ok my ApologiesThe post you quoted was from the Aug 18th, the first day alot of people received their devices.... The thread was brought back up because a lot of things make since now and some called heat issues on day 1
This thread is definitely creepy.... People reporting their phone is running hot while charging on day 1 and getting responses like "that's normal for new devices"....
These people had no idea that their phones were on the verge of the battery venting
It is normal to run elevated temps at first, but I think most people have a low idea of what's "hot" on a phone. So they may have had the wrong impression by the problem descriptions. Now if someone said their phone was pushing 130-150°F, there may have been more of a response because a phone shouldn't get that hot in normal ambient temps.This thread is definitely creepy.... People reporting their phone is running hot while charging on day 1 and getting responses like "that's normal for new devices"....
