Lost mobile data usage........6 hrs........apn settings seen right unless you can sgare yours,,,,,,,,,btw shows no wap setting..........before i have to can it or return for repairs
Lol
worth a try;;;;;;;;;did 3 resets
I'd go to T-Mobile and get a new SIM to see if that helps.Popped in ole sim card and all gone; 4 g stayed on when turned off wifi' but new tnmobilr gave me 2 g 4 g and 3 g but none had data when i turned wifi off then mobile data icon dropped out; samsing said device fine sim not so nor data 1 day after sim inserted'
Complain to John Legere on Twitter... He should be able to get you a replacement sim free since this is a service issue, not just buying a new simthey refused...............said will charge me 20///all bs
i like you moderators
most times, when disable wifi 4g would jump ship. it would show 3 bars and no 3 g or 4glte. just ordered another sim.
i feel its in vain. I HAVE UNLOCKED DEVICE, HOW ELSE WOULD I MAKE CALLS. for the most, data drops, wifi ok but when data dies no mms ability. yes you are and i are stumped. wont admit it but WAS or is vzw device, but tmobile sim service. say it. i can take it. it is unlocked period.
It doesn't do this. It's unlocked and will work with any SIM. That's what it means by being unlocked. You're describing a locked phone.Because even though all Verizon phones are factory unlocked...the Verizon firmware locks the LTE bands for use on AT&T and T-Mobile.
Just install the carrier firmware using Odin and you're good to go. Should be AP, CSC, .pit, and a couple more I'm missing. Don't have to mess with root or even APN settings once you install your carrier firmware. Then things like VVM work
