The Note 8 will obviously come with a USB-C charging cable, but, I like to have several additional cables handy. USB-C is unlike any other USB cable, in that you can actually damage a device if the cable isn't compatible (see this: https://androidcommunity.com/learn-why-non-compliant-usb-c-charging-can-damage-your-cables-20160908/ or just google "usb-c cable issues" for a sampling of issues).
I hate to purchase Samsung cables, as they are WAY more expensive than they should be, but, that may be the only choice, at least initially.
I'm certainly no expert on the subject - I'm just aware that there are issues. I purchased several USB-C cables for the Note 7, but suspect I won't even try them with the Note 8.
Anyone knowledgeable on the subject that may know some reliable USB-C cables?
