Been working with Bixby and it doesn't work any where close to Google assistant. When I hold down the Bixby button to talk and have it type sending a text, it only types first word.
Set it up for Bixby voice. I never use the button. It takes time to learn from youBeen working with Bixby and it doesn't work any where close to Google assistant. When I hold down the Bixby button to talk and have it type sending a text, it only types first word.
It keeps telling me it cannot hear my voice when I try to set up the voice wake up...
Have you tried changing the voice sensitivity. I use medium and it works great.
Mine is doing the same thing. Except when I push the button it hears me well then.It keeps telling me it cannot hear my voice when I try to set up the voice wake up...
Samsung needs to work on Bixby, what a big let down.
YouTube keeps triggering my Bixby Voice for some stupid reason. it's getting real annoying.
After your initial setup you should go into setting and read the section that explain what Bixby is and can do. Then study the tutorials. I use Bixby daily and it's learning me. Change your sensitivity settings so Bixby can hear you and be sure to hold down the Bixby button until you finish talking. I hope this helps because Bixby is real smart lol.I dumped the memory and the caches and started over. It recognizes a password to unlock it, does everything else, except it refuses to understand Hi Bixby! Not ready for primetime but maybe one day. Google Assistant is great, I agree.
