Has anyone tried the gear iconx 2018 with the Note 8? How is it? I'm thinking about purchasing them since they are on sale right now but wanted to know how the quality was first.
Is it really true that you can use them independently from one another. I don't usually have both earphones in at the same time.I just got my IconXs today, so it's a bit early. The pairing process is super simple, and they sound good so far. They immediately connect as soon as you take them out of the case. Voice access (Google Assistant or Bixby) works well with a tap and hold. The sound is a bit on the clear side, and good positioning and fit is crucial, like all of them. I get good bass when they are correctly inserted. I also own a pair of Jabra Sport wireless, I'm using that as a reference.
I'll be using them quite a bit this week for all my conference calls, etc. I'll have an update after that.
Reviews say you can choose to get phone calls in mono and choose which ear, so I'm expecting yes.Is it really true that you can use them independently from one another. I don't usually have both earphones in at the same time.
Do they still have the battery leak issue from the first year model?
how are they compared to the AKG we got with the Note 8?
I would like to know that either... Anyone comparing both?
Yes, have had them since around Xmas. Can def use 1 at a time. Very handy feature!Is it really true that you can use them independently from one another. I don't usually have both earphones in at the same time.
