I wouldn't recommend it. Besides, I'm not entirely sure it's a phone problem. My wife accidentally ran hers down to zero today and it charged back up with no worries. It shut off on its own and when I put it on my wireless charger it showed it charging. It powered up with no problems.I have yet to run my N8 down to 0 charge. Sometime during the warranty period, perhaps, I should purposefully do that to see if it will recharge. Yet, even if it does once is no guarantee it would continue to do so. Furthermore, it isn't good for the battery to run it down like that even as a test. I hope, therefore, that Samsung will replace or fix a phone outside of the warranty period should it have a charging problem. Maybe my hope, however, is a pipe dream.
First, discharging the battery even below 40% isn't healthy for the battery's life span. (Especially in a phone with a non-removable battery).
Second, charging a lithium battery that's been drained down to 0 can cause an explosion and/or fire, which is why the safety feature in all lithium batteries. gernerttl, I suspect that your wife's shutoff point is a bit above 0, so even though her phone shut off, the battery wasn't fully discharged. But discharging it to close to 0 on every charge cycle will kill the battery in a few months. (The manufacturers don't tell us that, because battery replacement is a high-profit job.)
If you can't charge the battery when it drops below 40%, shut it off. It's seldom worth $60 (unless Samsung raised the price) to do whatever you're doing at that point.
I've never heard of that rule either. LiIon and LiPoly batteries start to degrade after about 750ish (laptops are around 1000) cycles.This is interesting. I need to do more reading on batteries. I haven't always observed the 40% recharge rule. I always thought that recharging too often would also shorten the batteries life span.
I wouldn't try it. Without the proper tools and parts you'd lose the IP68 rating. That's one of the reasons why I got the S8+ and now a Note 8.On another note (no pun intended), how difficult would it be to replace the battery on these phones?
Don't forget Samsung has guaranteed theat after two years use we will only lose 2 percent of our charge.. No mention of how you charge it
That's because you're not one of the few with a defective battery (or at least a battery with defective/corrupted firmware). To be honest, had the Note 7 debacle not happened, this would be a non-issue.I've had my phone drop to 0% a few times and always managed to get my phone to charge. So far *knock on wood* I've not had any problems with charging and I've has this phone since September
