According to the specs, it should work on LTE, but interestingly, I don't think the Verizon variant supports T-Mobile's 3G bands:
https://forums.androidcentral.com/e...tphones/samsung-galaxy-note-8/&token=cgtF0EAr
https://support.t-mobile.com/docs/DOC-4988
So as long as you have good LTE signal, it should work ok.
This is correct. I have an unlocked T-Mobile Note 8 and when I insert a AT&T sim, the phone reboots, shows the AT&T boot up logo as if it were an AT&T branded phone and everything works, including WiFi calling. Even all the AT&T bloat installs including DirecTV and the MyAT&T app.If you're on Oreo, it would automatically switch to T-Mobile firmware when you add the T-Mobile sim. All US Note 8's have the same hardware, so they can work on any carrier. I just picked up a Verizon Note 8 on Swappa and received it today, once I put my T-Mo sim in, it restarted and added T-Mo's apn, carrier splash screen on bootup, wi-fi calling feature, and bloat. I'm now flashing the unlocked firmware to get rid of all that though lol.
