Notification Panel Resets to Default on its own
oceanrealm
51
After moving the 5 notifications I prefer into the top active row, the panel resets itself to the default spontaneously (usually within 5-10 minutes). I prefer to add Airplane Mode and Do Not Disturb to the top 5 rows, but again my Sprint Note Edge keeps resetting to default.... Frustrating but not a major problem. I cleared the cache partition several times. Anyone else having this issue?
oceanrealm
51
UPDATE: One of the panels that kept positioning itself was WiFi Calling. So I decided to manually reset the Notification Panels to default and noticed that WiFi Calling was no longer present. So something I added/updated recently must have added Wifi Calling, and it kept forcing its way into the top 5. After resetting I manually moved my preferred Notification Panels to the top 5. It's been an hour and no problems. I will update if the problem re-occurs!!
m1000
