Remote control Galaxy Note Pro 12.2 from Note 4 phone?
Dec 15, 2014
5
Wondering if it is possible to do this. I can use Teamviewer to control PC from Phone or Tablet, but can't control one android device from another.
For instance, in a face to face meeting I would like to set my Galaxy Note Pro 12.2 in front of the Client I am meeting with and show them a presentation I am running from my phone. Initially, I thought the Screen Mirroring tool on the Tablet would be able to do this, but it will only share its screen with a TV via Roku or another player.
You can't do it your way, but if you can run the presentation on the tablet, you can control it from your phone.
Put a VNC server on the tablet (any one will work.) Put a VNC viewer on the Note 4. Run the server. Run the viewer. Once they're connected, you'll see the tablet's screen on the Note 4 and whatever you do on the Note 4 will happen on the tablet. It's something like Team Viewer.
You'll need a wifi connection they can both connect to, but you can probably still get a D-Link DWG-G730AP access point and carry it with you just in case. (It sits in a 4-1/2" X6" zippered case, so it's easy to throw into an attache case.) I've seen them sell on eBay from as little as $5 to as much as $40 still in the box. Handy also if you're in a hotel with an old Ethernet internet connection and two of you want to use it at the same time. The 730 can function as a wifi adapter for a device tat doesn't have wifi, a router or an access point (only 1 at a time). And the device itself is small enough to hide in one hand. (There's a USB cable and a plug-in power supply included in the case.)
Where do you find VNC server? Would the side sync app do the same? I am using a Galaxy S4 not a note 4?
Side sync worked fine between my Note 12.2 and Note 3. Just could not think of a good reason to keep doing it. VNC , I think any portable WIFI router would work.
kimswid48
