Hello everyone! Can you share your own experience with multitasking and multiwindow apps on Note Pro 12.2? Which apps are you using and why?
Thank you!!!
Thank you!!!
This looks good, have you tried it in Note 12.2? Is there a way to have multiple instances of chrome in multiwindow?
I will be able to open multiple instances of chrome using the pen floating window feature, is that correct?
Samsung GALAXY NotePRO 12.2 - Multi-Window-Modus: http://youtu.be/b_hQ6r0BRrM
Please see this video on 01:06 it shows that we can open 2 instances of an app. Does this work with chrome?
I never knew you could do that. I'll have to check tonight when I get home.
One other option is to run both the Chrome app and the Chrome Beta app at the same time. They are both Chrome but one is a but more bleeding edge (Beta) than the other. I've not tried this but it should work.
https://forums.androidcentral.com/e...pps/details?id=com.chrome.beta&token=uHRA_ZdU
